Linear
Linear pattern grouping allows you to force OptiStruct to create beads in a given direction along the entire length of the part.
This can be very useful for optimizing the shape of extruded parts which must maintain a constant cross section. It is also very useful when optimizing the side walls of stamped plates whose beads must run from the top to the bottom so that the part can be drawn from the die. In solid models, where the variable needs to control the movement of all grids through the thickness, linear pattern grouping is also very useful.
