Cyclical
The cyclical pattern grouping allows you to force OptiStruct to create a series of symmetric shape variables about a central axis that repeat a number of times determined by you (with the UCYC field).
This can be useful in assigning a reinforcement pattern in a circular plate that matches an angularly repeated load in a symmetric fashion.
OptiStruct allows any number of repeated cyclical wedges by entering the number of desired wedges into field 30 (UCYC). OptiStruct internally calculates the repetition angle according to the formula 360.0/UCYC. For example, setting UCYC to three results in three wedges of 120.0 each, and setting UCYC to 6 results in six wedges of 60.0 each.
Other Forms of Cyclical Pattern Grouping
OptiStruct supports the combination of cyclical pattern grouping with one plane symmetry, linear pattern grouping, radial pattern grouping, and radial linear pattern grouping. Each option is specified with a different base TYP number to which the number denoting the repetition angle is added.
For radial linear cyclical pattern grouping (TYP=80 and 81), OptiStruct generates a series of planes that run radially away from and in the same plane as the first vector. The radial linear cyclical pattern grouping is essentially the linear cyclical pattern grouping combined with the radial pattern grouping. The full lengths of the radially drawn shape variables will be cyclically symmetric.
