Bulk Data Entry Defines coefficients of a power series for use in
    generating temperature-dependent material properties. Also contains parametric data for use with
    the table.
              | (1) |
              (2) |
              (3) |
              (4) |
              (5) |
              (6) |
              (7) |
              (8) |
              (9) |
              (10) |
              | TABLEM4 |
              TID |
              X1 |
              X2 |
              X3 |
              X4 |
              A0 |
              A |
              A |
              A |
              A |
              A |
              etc. |
              | (1) |
              (2) |
              (3) |
              (4) |
              (5) |
              (6) |
              (7) |
              (8) |
              (9) |
              (10) |
              | TABLEM4 |
              28 |
              0.0 |
              1.0 |
              0.0 |
              100 |
              2.91 |
              -0.0329 |
              6.51-5 |
              0.0 |
              -3.4-7 |
              ENDT |
              | Field |
              Contents |
              SI Unit Example |
              | TID |
              Table identification number. (Integer
                  > 0)  |
              | Xi |
              Table parameters. (Real; X2 ≠ 0.0; X3
                  < X4)  |
              | Ai |
              Coefficients. (Real)  |
                                                - At
                                                  least one continuation entry must be
                                                  specified.
                                                - The
                                                  end of the table is indicated by the existence of
                                                  ENDT in the field following the
                                                  last entry. An error is detected if any
                                                  continuations follow the entry containing the
                                                  end-of-table flag ENDT.
                                                - TABLEM4 uses the algorithm:
Where,
                - Input to the table
                - Is returned
                - Is supplied from the MATi entry
Whenever
              , use X3 for
              ; whenever
              , use X4 for
              . There are N + 1 entries in the table. There are no error
            returns from this table look-up procedure.
                                                - This
                                                  card is represented as a load collector in
                                                  HyperMesh.
