Bulk Data Entry Controls the search behavior for auxiliary points for CFAST
elements.
The search for CFAST auxiliary points is conducted by using
GSMOVE (particular
GS/GA/GB) as the outer
loop, NREDIA (particular diameter) as the inner loop, and the
actual auxiliary point search as the innermost loop.
| Parameter |
Values |
Description |
| ASCHAUX |
<NO, YES> |
- NO (Default)
- The search for auxiliary points will be limited to
shells with the same PSHELL
property. However, if the user-defined
GSMOVE and
NREDIA parameters are reached
(as described above), and the shells for auxiliary
points cannot be found, then the limit of searching
within the same PSHELL property
will be overridden. The search is then expanded into
different PSHELL properties for
additional attempts.
- YES
- The search of auxiliary points will not be limited
to shells with the same PSHELL
property for every attempt within the specified
GSMOVE and
NREDIA. Within the same
GSMOVE and
NREDIA parameters, the search
attempts start from the shells with the same
PSHELL property and are
expanded into shells with different
PSHELL properties until the
search is successful. If no such auxiliary points
are found, then the GSMOVE and
NREDIA parameters are updated
and the search begins again.
