SUBSEQ
Subcase Information Entry Gives the coefficients for forming a linear combination of the previous static subcases.
SUBSEQ=R1, [R2, R3, ..., Rn]
SUBSEQ=1.0, -1.0, 0.0, 2.0
| Argument | Description |
| Ri | Coefficients of the
                                previously occurring static subcases. (Real)  |
- Can only appear after a SUBCOM command.
 - R1 to
                    Rn refer to the immediately preceding static subcases.
                    Rn is applied to the most recently appearing static subcase,
                    R(n-1) is applied to the second most recently appearing
                static subcase, and so on. The embedded comments ($) describe the following example:
DISPL = ALL SUBCASE 1 SUBCASE 2 SUBCOM 3 SUBSEQ = 1.0, -1.0 $ SUBCASE 1 - SUBCASE 2 SUBCASE 11 SUBCASE 12 SUBCOM 13 SUBSEQ = 0.0, 0.0, 1.0, -1.0 $ SUBCASE 11 - SUBCASE 12 or SUBSEQ = 1.0, -1.0 $ EQUIVALENT TO PRECEDING COMMAND. USE ONLY ONE.
