SUBCASE
Subcase Information Entry The SUBCASE command can be used to indicate the start of a new subcase definition.
SUBCASE = integer
| Argument | Description |
| integer | Subcase identification
                                number (SID). No default (Integer > 0)  |
- Each subcase must be declared with a separate SUBCASE header and a unique SID.
 - The SUBCASE header is not needed, if there is just one subcase.
