The .strs file is an OptiStruct
        ASCII format results file.
File Creation
This file is created when the OPTI, OS or BOTH formats are chosen. (See documentation for the I/O Option OUTPUT).
File Contents
                            | Result |
                            Description |
                            | Stress |
                            Stress results from linear
                                static analysis and linear transient analysis.  Output is
                                    controlled by the I/O Option STRESS (or ELSTRESS).  |
File Format
            The stress file has the following format for linear static analysis:
                                | For
                                    each iteration, the following header is used: |
                                iter |
                                Iteration |
                                Numlds |
                        - Data
                        - Description
                        - iter
                        - Keyword denoting the beginning of a new iteration.
                        - Iteration
                        - Iteration number.
                        - Numlds
                        - Number of load cases for which this output is created.
            For each iteration, the following header is used:
                                | Each iteration section is divided up by subcase.
                                    Output for each subcase starts with a line in the following
                                    format: |
                                Id |
                                Number_of_els |
                                STRS:Spc_id(Datatype) |
                        - Data
                        - Description
                        - Id
                        - Output identification number for the subcase. This is not the same as
                            the subcase ID used in the input data.
                        - Number_of_els
                        - Number of elements for which this output is requested.
                        - STRS
                        - Fixed keyword.
                        - Spc_id
                        - SID for SPC's referenced by this subcase.
                        - Datatype
                        - Keyword indicating the type of subcase involved.
                        - LOAD declares data is for a linear static subcase.
            Stress information is then provided, for each element, in the following format:
                                EID |
                                Stress1 |
                                Stress2 |
                                Stress3 |
                                Stress4 |
                                Stress5 |
                                Stress6 |
                                Stress7 |
                                Stress8 |
                                Stress9 |
                        - Data
                        - Description
                        - EID
                        - Element identification number.
                        - Stress1
                        - von Mises stress for 2D and 3D elements, Maximum Longitudinal stress for
                                BAR/BEAM 1D elements, or Axial
                            stress in CWELD elements.
                        - Stress2
                        - Normal X-stress at Z1 for 2D elements, Normal X-stress for 3D
                            elements.
                        - For BAR/BEAM it is the
                            longitudinal stress at C at end A. Maximum tensile stress at end A for
                                CWELD elements.
                        - Stress3
                        - Normal X-stress at Z2 for 2D elements, Normal Y-stress for 3D elements,
                            or Axial stress for 1D elements.
                            longitudinal stress at D at end A. Minimum tensile stress at end A for
                                CWELD elements.
                        - Stress4
                        - Normal Y-stress at Z1 for 2D elements, Normal Z-stress for 3D elements,
                            longitudinal stress at E at end A. Maximum tensile stress at end B for
                                CWELD elements.
                        - Stress5
                        - Normal Y-stress at Z2 for 2D elements, Shear XY-stress for 3D elements,
                            longitudinal stress at F at end A. Minimum tensile stress at end B for
                                CWELD elements.
                        - Stress6
                        - Shear XY-stress at Z1 for 2D elements, Shear YZ-stress for 3D elements,
                            longitudinal stress at C at end B. Maximum shear stress for
                                CWELD elements.
                        - Stress7
                        - Shear XY-stress at Z2 for 2D elements, Shear XZ-stress for 3D elements,
                            longitudinal stress at D at end B. Bearing stress for
                                CWELD elements.
                        - Stress8
                            longitudinal stress at E at end B.
                        - Stress9
                            longitudinal stress at F at end B.
                        - Stress10
                        - For BAR/BEAM it is the Axial
                            stress.
            The stress file has the following format for linear transient analysis:
                                | For each
                                iter |
                                Iteration |
                                NumIds |
                        - Data
                        - Description
                        - iter
                        - Keyword identifying that the next field is the iteration number.
                        - Iteration
                        - The iteration number.
                        - NumIds
            Each section under iteration is divided up by subcase. Output for each subcase starts
                with a line in the following format:
                                | Subcase |
                                Id |
                                Label |
                                | Time |
                                Time |
                                | Result Type |
                                (Entity
                                        Type) |
                                [Format] |
            Where,
                        - Data
                        - Description
                        - Id
                        - Label
                        - Subcase level.
                        - Time
                        - Time increment information.
                        - Entity Type
                        - Beam, Rod, Plate, and so on.
                        - Format
                        - Complex, Real, Imaginary, Phase, and so on.
            The strain result format information is the same as the linear static analysis
                format.
                - The I/O Option Previously Supported Results controls
                    the frequency of output for analytical results during an optimization.
