SPOINT
Bulk Data Entry Defines scalar points.
SPOINT | ID1 | ID2 | ID3 | ID4 | ID5 | ID6 | ID7 | ID8 |
Alternate Format
SPOINT | ID1 | "THRU" | ID2 |
SPOINT | 3 | 18 | 1 | 4 | 16 | 2 | 6 | THRU | |
8 | 47 | 99 | THRU | 128 |
ID# | Unique scalar point identification number. No default (0 > Integer) |
- A scalar point defined by its appearance on the connection entry for a scalar element (see the CELAS, CMASS, and CDAMP entries) does not need to appear on an SPOINT entry.
- This entry is used primarily to define scalar points appearing in single-point or multipoint constraint equations to which no scalar elements are connected.
- If the alternate format is used, all scalar points ID1 through ID2 are defined. ID1 must be less than ID2.
- Alternate format can be combined with regular format, and it can span across continuation lines.
- This card is represented as a node in HyperMesh.
