Specialized Result Outputs
| Keyword | Description | Default Frequency | Affected Files | Options | Details |
| ADAMSMNF | Output of flexible body to a modal neutral file for MSC.ADAMS. 17 | - | *.mnf | <YES,
                                    NO> Default = YES  |
| HGFREQ | Frequency Analysis output presentation for HyperGraph. 3 | FL | *_freq.mvw, *_s#_a.frf, *_s#_d.frf, *_s#_v.frf  |
| HGTRANS | Transient Analysis output presentation for HyperGraph. 2 3 28 | - | *_tran.mvw, *_s#_a.trn, *_s#_d.trn, *_s#_s.trn, *_s#_v.trn  |
| HGMBD | - | *_mbd.mvw, *_s#_a.mbd, *_s#_d.mbd, *_s#_v.mbd  |
| HGEFFMASS | Effective mass is output as a HyperGraph bar chart via the BAR option (default), or as a HyperGraph XY plot via XY option. | - | *.mass,
                                     *_mass.mvw  |
| HGMODFAC | Modal participation factor output presentation for HyperGraph 3D. 14 | FL | *_modal.mvw, *_modal.#.mvw  |
                            <REGULAR, NORM> Default = REGULAR  |
| MASSPROP | Controls the output of Center of Gravity and Mass Moments of Inertia tables based on properties to .out file. 20 | FL | *.out | - | The center of gravity is specified in the basic coordinate system. The Mass Properties are printed in two tables: one with respect to the center of gravity of the item, and the other with respect to the origin of the basic coordinate system. |
| MASSCOMP | Controls the output of mass based on HyperMesh components to the .out file. | FL | *.out | - | The center of gravity is specified in the basic coordinate system. The Mass Properties are printed in two tables: one with respect to the center of gravity of the item, and the other with respect to the origin of the basic coordinate system. |
| MODES | Controls the printing of modes to the .out file from normal modes or modal dynamic optimization runs. | ALL | *.out | - | The default is
                                    ALL, that is modes extracted are printed to the
                                    .out file for all optimization
                                    iterations. All frequency options except CONV and CURRENT are applicable to OUTPUT,MODES.  |
| REGCOMPL | Controls the output of regional compliance table to .out file. | *.out | <YES,
                                    NO> Default = YES  |
                            24 | |
| KPI | Controls the output of Key Performance Indicators to .kpi file (ASCII). | FL | *.kpi | - | 24 |
| MATRIX | Controls the output of Stiffness, Mass, Grid-to-DOF mapping, Heat Capacity, Conductivity, Convection, and the Grid to Heat DOF mapping matrices to .full.mat and .reduced.mat files (ASCII). | - | *.reduced.mat,
                                         *.full.mat  |
                            Option
                                        1: <FULL, REDUCED> No default Option 2: <DENSE, SPARSE> Default = DENSE Option 3: <'format'> Default = Blank |
                            The FULL and
                                    REDUCED options control whether the full or
                                reduced matrices are output to the .full.mat and .reduced.mat
                                ASCII files.  An additional optional control, DENSE and SPARSE allows control over whether to output the fully dense matrices or to only output the sparse matrices (without zeros). The
                                    third option allows you to control the precision and format of
                                    the output. The format is defined using the Fortran syntax,
                                    which provides the number of entries per line, followed by the
                                        precision. Note: The format should be enclosed in single
                                        quotes. A couple of examples:
| PCOMP | Output equivalent PCOMPG from the ply-based modeling (STACK/PCOMPP) input. | - | *.pcomp | - | This is supported for analysis and optimization. The Frequency option is not supported for this keyword. |
| ESDAMP | Controls the output of Strain energy proportional damping to .kpi file (ASCII). | FL | *.esdamp | - | 29 |
