Bulk Data Entry Defines the interior grid points for One-Step
        Superelement Analysis.
                            | (1) |
                            (2) |
                            (3) |
                            (4) |
                            (5) |
                            (6) |
                            (7) |
                            (8) |
                            (9) |
                            (10) |
                            | SESET |
                            SEID |
                            G1 |
                            G2 |
                            G3 |
                            G4 |
                            G5 |
                            G6 |
                            G7 |
        Alternate Format
                            | (1) |
                            (2) |
                            (3) |
                            (4) |
                            (5) |
                            (6) |
                            (7) |
                            (8) |
                            (9) |
                            (10) |
                            | SESET |
                            SEID |
                            G1 |
                            THRU |
                            G2 |
                            | (1) |
                            (2) |
                            (3) |
                            (4) |
                            (5) |
                            (6) |
                            (7) |
                            (8) |
                            (9) |
                            (10) |
                            | SESET |
                            4 |
                            333 |
                            12 |
                            556 |
                            99 |
                            5 |
                            | Field |
                            Contents |
                            SI Unit Example |
                            | SEID |
                            Superelement
                                identification number. No default (Integer ≥ 0)  |
                            | Gi |
                            Grid or Scalar Point
                                identification numbers. Default = Blank (Integer > 0, or
                                        THRU)  |
                - Grid point entries via
                        Gi should not be repeated on the SESET
                    entry.
                - If the THRU option
                    is used, then G1 should always be less than
                        G2.
