SENSITIVITY
I/O Options and Subcase Information Entry The SENSITIVITY command can be used in the I/O Options section to request the output of the responses and sensitivities for size and shape design variables to a Microsoft Excel spreadsheet.
SENSITIVITY = option
| Argument | Options | Description |
| option | <YES,
                                    NO, ALL, NONE,
                                    STRESS, NOSTRESS> Default = NONE  |
- This command is ignored when OUTPUT, MSSENS command is present.
 - The frequency of this output is controlled by the SENSOUT option.
 - For more details on the output format, refer to #.slk file.
 - Additional sensitivity output requests for topology, free-sizing and gauge design variables can be made through OUTPUT and OUTPUT (in H3D format), and OUTPUT (ASCII format).
