RJOINT
Bulk Data Entry Defines a Rigid Joint connection at two coincident grids.
| RJOINT | EID | GA | GB | CB |
| RJOINT | 2 | 3 | 1 | 234 |
| EID | Rigid Joint Element
                                identification number. No default Integer > 0)  |
| GA | Grid Point identification
                                number of the first grid point. No default (Integer > 0)  |
| GB | Grid Point identification
                                number of the coincident second grid point. No default (Integer > 0)  |
| CB | Components in the global
                                coordinate system at grid point GB. These
                                degrees-of-freedom are rigidly constrained with the same
                                degrees-of-freedom of GA. Default =blank (blank or Integers 1 to 6 with no embedded blanks)  |
- The two grid points GA and GB should be coincident (the distance between grid points should be zero).
 - If CB field is set to blank, the default value is 123456, the two grid points GA and GB move as a single point.
 - If all six components are not input on the
                    CB field, then depending on the number of free components,
                the joint behavior of the RJOINT varies.
- If CB=12345, RJOINT behaves like a hinge.
 - If CB=1234, RJOINT works as a universal joint.
 - If CB=123, RJOINT works as a spherical joint.
 - RJOINT does not incorporate thermal expansion effects since the distance between grid points GA and GB is zero.
 - RJOINT element identification numbers should be unique compared to any other element in OptiStruct.
