RANDT1
Bulk Data Entry Defines time lag constants for use in random analysis autocorrelation function computation.
RANDT1 | SID | N | T0 | TMAX |
RANDT1 | 5 | 10 | 3.2 | 9.6 |
SID | Random analysis set
identification number. (Integer > 0) |
N | Number of time lag
intervals. (Integer > 0) |
TO | Starting time lag. (Real ≥ 0.0) |
TMAX | Maximum time lag. (Real > TO) |
- At least one RANDPS entry must be present with the same set identification number.
- The time lags defined on this entry are
given by:Ti=To+Tmax−ToN(i−1),i=1,N+1
- Similar to RANDPS Bulk Data Entries, the RANDT1 Bulk Data Entries can be referenced either by:
- If a SET
entry is used to reference multiple RANDPS data, then the
RANDT1 entry with the smallest ID from set of referenced
entries will be selected for the analysis.For example:
RANDOM=2 SET 2 = 5,6,7 BEGIN BULK $ RANDPS,5 RANDPS,6 RANDPS,7 $ RANDT1,5 → This RANDT1 entry is selected for analysis. RANDT1,6
