PTADD
Bulk Data Entry Defines a pretension load as a linear combination of load sets defined via PTFORCE, PTFORC1, PTADJST and PTADJS1 entries.
PTADD PSID S S1 L1 S2 L2 S3 L3
S4 L4 etc.
PTADD 6 2.0 3.0 2 2.0 3
PSID Pretensioning load set identification number.
S Scale factor. 1
No default (Real)
Si Scale factor. 1
No default (Real)
Li Pretension load set identification number defined via entry types enumerated above. 1
No default (Integer > 0)
  1. The pretension load as a linear combination is defined by:
    P=SiSiLi
    Where,
    S and Si
    Scale factors
    Li
    Pretension load set defined via PTFORCE, PTFORC1, PTADJST and PTADJST entries.
