PROPERTY
I/O Options and Subcase Information Entry The PROPERTY command can be used in the I/O Options section to request the output of the property definitions used in the final iteration of an optimization.
PROPERTY = option
| Argument | Options | Description |
| option | <FILE,
                                    OUT, BOTH,
                                    NONE> Default = FILE  |
