PLOTEL4
Bulk Data Entry Defines a four-noded, two-dimensional dummy element for use in plotting.
| PLOTEL4 | EID | G1 | G2 | G3 | G4 |
| PLOTEL4 | 29 | 35 | 16 | 22 | 23 |
| EID | Unique element identification number.
                  Unique with respect to all other element identification numbers. No default (Integer > 0)  |
| G1, G2, G3, G4 | Grid point identification numbers of
                  connection points. No default (Integer > 0; G1 ≠ G2 ≠ G3 ≠ G4)  |
- This element is not used in the model during any of the solution phases of a problem. It is used to simplify the plotting of large structures.
 - This card is represented as a quad4 element in HyperMesh.
