PLOADXG
Bulk Data Entry Defines a surface traction on the general axisymmetric elements CQAXIG and CTAXIG.
PLOADXG SID EID GA GB CID N1 N2 N3
PA PB
PLOADXG 3 20 11 13 82 1.0 0.0 0.0
10.5 12.5
SID Load set identification number.
No default (Integer > 0)
EID Element identification number.
PA Surface traction at grid point GA.
No default (Real)
PB Surface traction at grid point GB.
No default (Real)
GA, GB Identification numbers of two adjacent corner grid points on the element side.
CID Coordinate system identification number. A CID of zero or blank identifies the basic coordinate system.
Default = 0 (Integer ≥ 0, or blank)
N1, N2, N3 Components of a vector measured in the coordinate system specified by CID. The vector defines the direction of the load and is normalized internally such that it does not contribute to the magnitude of the load. If N1, N2 and N3 are all blank, the in-plane inward normal is used as default.
Default = In-plane inward normal (Real or all blank)
  1. The surface traction is assumed to vary linearly along the element side between GA and GB.
    Figure 1. PLOADXG Definition
  2. The surface traction is input as force per unit area.
