PFBODY
Bulk Data Entry Defines a flexible body out of a list of finite element properties, elements, and grid points.
PFBODY | BID | BODY_NAME | |||||||
TYPE1 | ID1 | ID2 | ID3 | ID4 | ID5 | ID6 | ID7 | ||
ID8 | etc | ||||||||
TYPE2 | ID9 | ID10 | etc | ||||||
TYPE# | etc | ||||||||
etc | |||||||||
CMS | CTYPE | UB_FREQ | NMODES | ||||||
FLXNODE | NOAUTO/ C |
G1 | G2 | G3 | G4 | G5 | G6 | ||
FLXNODE | C | G8 | G9 | etc | |||||
etc | |||||||||
DAMPING | DTYPE | DVAL |
Example 1
PFBODY | 3 | Control_arm | |||||||
PSHELL | 23 | 21 | |||||||
PBEAM | 9 | 59 | 48 | ||||||
CONM2 | 2345 | ||||||||
GRID | 400 | 401 | 402 | ||||||
CMS | CB | 50 | |||||||
FLXNODE | 123 | 400 | 499 | ||||||
FLXNODE | 123456 | 402 | 300 |
Example 2
PFBODY | 3 | Linkage | |||||||
PSOLID | 13 | 15 | |||||||
CMS | CB | 2000.0 | |||||||
FLXNODE | NOAUTO | ||||||||
FLXNODE | 123 | 900 | 901 | 902 | 903 | 1000 | 1001 | ||
FLXNODE | 123456 | 11 | 12 | 13 | |||||
DAMPING | CRATIO | 0.8 |
BID | Unique body identification
number. No default (Integer > 0) |
BODY_NAME | Unique body name. This name is used as the Flex H3D file name to which the reduced flexible body information will be written out for the PFBODY. Default = OUTFILE_body_<BID>.h3d (Character string) |
TYPE# | Indicates that the following list of
IDs refer to entities of this type. All property definitions;
CELAS2, CONM2, PLOTEL,
RBE2, RBE3, RBAR,
RROD, and GRID are valid types for this
field. No default (PBAR, PBARL, PBEAM, PBEAML, PBUSH, PCOMP, PCOMPP, PCOMPG, PDAMP, PELAS, PGAP, PROD, PSHEAR, PSHELL, PSOLID, PVISC, PWELD, CELAS2, CONM2, PLOTEL, RBE2, RBE3, RBAR, RROD, or GRID) |
ID# | Identification numbers of entities of
the preceding TYPE flag. No default (Integer > 0) |
CMS | Indicates that information on the method used for reducing the flexible body is to follow. | |
CTYPE | Component Mode Synthesis method to be
employed.
UB_FREQ | Upper bound frequency for the
eigenvalue analysis. Default = blank (Real > 0.0, or blank) |
NMODES | Number of modes to be extracted from
eigenvalue analysis. Default = blank (Integer > -1, or blank) |
FLXNODE | Indicates that flexible body interface node information is to follow. 11 | |
NOAUTO | Flag to not automatically determine the interface nodes for the flexible body. | |
C# | Component number indicating the
interface degrees-of-freedom for the following list of grids. No default (up to 6 unique digits (0 < digit ≤ 6) may be placed in the field with no embedded blanks) |
G# | Grid identification
numbers. (Integer > 0) |
DAMPING | Indicates the flexible body modal damping. | |
DTYPE | Damping option.
DVAL | Damping ratio value, if
DTYPE is specified as CRATIO. (Real ≥ 0.0) |
- A maximum of 56 characters may be given for BODY_NAME.
- Flex H3D file name will be <BODY_NAME>.h3d or OUTFILE_body_<BID>.h3d in the outfile directory.
- Any number of property definitions; CELAS2, CONM2, PLOTEL, RBAR, RBE2, RBE3 or RROD elements or grid points can be given.
- At least one property definition, element, or grid point must be given.
- A property definition; CELAS2, CONM2, PLOTEL, RBAR, RBE2, RBE3 or RROD element or grid point can only belong to one body (flexible or rigid).
- All property definitions, elements and grid points defined on a PFBODY Bulk Data Entry form one flexible body.
- CMS definition defines the component mode synthesis method to reduce the flexible body for the multibody analysis. Exactly one must be defined for each PFBODY.
- UB_FREQ and NMODES cannot both be blank.
- When UB_FREQ = 0.0 and NMODES = 0, this is a special case where no eigen modes will be included in CMS mode generation.
- If FLXNODE is not defined, a default set of interface nodes and degrees-of-freedom will be generated, based on the actual interface nodes and degrees-of-freedom of the flexible body.
- One FLXNODE line can have up to six interface grid IDs. No continuation lines are allowed. Add multiple FLXNODE lines to add more than six interface nodes.
- ASSIGN can
be used in two ways, to identify flex body for result recovery or in further OS-MBD analysis
in the PFBODY Bulk Data Entry.
- Identifies an external nodal flexh3d file which contains the analysis recovery information for displacements, velocities, accelerations, stresses and strains. Provides a Flex Body ID for the information therein, and the path to the name of the flexh3d file.
- The identified flexh3d file can also be used as a flex body in OS-MBD analysis. This can be activated by referencing the Flex Body ID on the BID field of the PFBODY Bulk Data Entry. In such cases, the included flex body (ASSIGN, H3DMBD, Flex Body ID) is used in the analysis and the PFBODY information for flex body generation is not used.
- This card is represented as a group in HyperMesh.
