PCOMPLS
Bulk Data Entry Defines global ply-based composite properties for continuum shell composites.
Format - Implicit
| PCOMPLS | PID | CORDM | SB | LAYERWISE | |||||
| C8 | INT8 | ||||||||
| STACKD | DIR | SDIR | |||||||
| ID1 | MID1 | T1 | THETA1 | ||||||
| ID2 | MID2 | T2 | THETA2 |
Format - Explicit
| ID2 | MID2 | T2 | THETA2 | ||||||
| EXPLICIT | NIP |
Example 1
| PCOMPLS | 100 | ||||||||
| C8 | ASTN | ||||||||
| STACKD | DIR | 1 | |||||||
| 120 | 1 | 0.9 | 45.0 | ||||||
| 121 | 2 | 0.6 | 90.0 |
Example 2
| STACKD | CORDM | 2 | |||||||
| PID | Unique composite
                                    property identification number. No default (Integer > 0)  |
| CORDM | Identification number
                                    of the material coordinate system. Default = 0 (Integer)  |
| SB | Shear stress limit of
                                    bonding material (interlaminar shear stress limit). (Real > 0.0)  |
| LAYERWISE | Defines lamination
                                    theory for heat transfer.
| C8 | Flag indicating that the subsequent field applies to referenced CHEXA and CPENTA solid elements. | |
| INT8 | Integration type.
| STACKD | Flag indicating that the subsequent field applies to define stack direction. | |
| DIR | Stack direction
                                    definition type.
 No default (Char)  |
| SDIR | The auxiliary
                                    direction used to determine stack direction. When
                                            DIR = DIR
 When DIR =
                                            CORDM
| IDi | Global Ply ID. No default (Integer > 0)  |
| MIDi | Material ID for the
                                    ply defined via the previous IDi field.
                                    Currently MAT1, MAT9,
                                        MAT9ORT, and MATUSR
                                    materials are supported.  No default (Integer > 0)  |
| Ti | Defines the
                                    user-defined ply thickness of the ply specified via the
                                        IDi field. 6 No default (Real > 0.0)  |
| THETAi | Orientation angle of
                                    the ply within the ply plane. 4
                                    5 Default = 0.0 (Real)  |
| EXPLICIT | Flag indicating that parameters for Explicit Dynamic Analysis are to follow. | |
| NIP | Number of through
                                    thickness integration points.  Default = 3 (1 ≤ Integer ≤ 10)  |
- The global Ply ID should be unique with respect to other ply's on this PCOMPLS entry.
 - The PCOMPLS entry is only supported for first order CHEXA and CPENTA elements.
 - The Global Ply IDs uniquely identify ply's across all PCOMPG and PCOMPLS entries.
 - The thickness direction of the composite element by default starts from face G1-G2-G3-G4 to face G5-G6-G7-G8 of the solid element. Ply numbering also follows this thickness direction. This is used to only determine the direction of the local Z axis of the plies. The local Z-axis of each ply is perpendicular to the ply plane and aligned to the thickness direction. The X-axis of the coordinate system defined via CORDM (basic system, if blank) is projected onto the ply plane to determine the local X axis for the ply. The local Y-axis is then determined by the cross-product of the local X and Z axes.
 - The orientation angle is measured in the positive counter clockwise direction from this projected X-axis about the local Z axis of the ply.
 - The actual ply thicknesses depend on
                    the actual total geometric thickness of the solid element:Where,
- Actual thickness of the Ply “I”
 - Actual (or geometric) thickness of the composite element
 - User-defined ply thicknesses via the Ti field
 - Setting the LAYERWISE field to 1 offers an option for through-thickness degrees of freedom. Each layer has four internal nodes, one on each face. This option offers greater accuracy but is more computationally expensive. Setting LAYERWISE option to 1 applies a piecewise linear temperature distribution through the laminate thickness. This field only applies to Heat Transfer Analysis.
 - When using STACKD,CORDM,[OPTION] to define the stack direction, the x-, y-, or z-axis of the material's coordinate system serves as an auxiliary vector. The angle between this auxiliary vector and each element coordinate axis is calculated, and the element axis with the smallest angle is selected as the stack direction. If two element axes have nearly identical angles with the auxiliary vector (with an angle discrepancy of less than 10 degrees), an error is triggered. In this case, you are advised to use an alternative method to define the stack direction.
