PBAR
Bulk Data Entry Defines the properties of a simple beam (bar), which is used to create bar elements via the CBAR entry.
| PBAR | PID | MID | A | I1 | I2 | J | NSM | ||
| C | C | D | D | E | E | F | F | ||
| K | K | I12 |
| PBAR | 39 | 6 | 2.9 | 8.4 | 5.97 | 1.1 | |||
| 2.0 | 4.0 |
| PID | Unique simple beam
                                property identification.
 No default (Integer > 0 or <String>)  |
| MID | Material identification.
                                    1
                                2
| A | Area of bar
                                    cross-section. No default (Real ≥ 0.0)  |
| I1 | Area moment inertia in
                                plane 1 about the neutral axis. No default (Real ≥ 0.0)  |
| I2 | Area moment inertia in
                                plane 2 about the neutral axis. No default (Real ≥ 0.0)  |
| I12 | Area product of
                                    inertia. Default = 0.0 (Real) (I1 > 0,. I2 > 0., I1 * I2 > I122)  |
| J | Torsional
                                    constant. Default = 0.0 (Real > 0.0)  |
| NSM | Nonstructural mass per
                                unit length. Default = 0.0 (Real)  |
| K, K | Area factor for
                                    shear. Default = 0.0 (Real)  |
| Ci, Di, Ei, Fi | Stress recovery
                                    coefficients. Default = 0.0 (Real)  |
- For structural problems, MID may reference only a MAT1 material entry. For heat transfer problems, MID may reference only a MAT4 material entry.
 - String based labels allow for easier visual identification of properties, including when being referenced by other cards. (For example, the PID field of elements). For more details, refer to String Label Based Input File in the Bulk Data Input File.
 - The transverse shear stiffness in planes 1 and 2 are (K)AG and (K2)AG, respectively. The default values for K and K are infinite; in other words, the transverse shear flexibilities are set equal to zero. K and K are ignored if I12 ≠ 0. If a value of 0.0 is used for K and K, the transverse shear flexibilities are set to 0.0 (K and K are interpreted as infinite).
 - The stress recovery coefficients C and C, and so on, are the y and z coordinates in the BAR element coordinate system
                    of a point at which stresses are computed. Stresses are computed at both ends of
                    the BAR.
Figure 1. Coordinate System for Bar Element (PBAR)
 - The moments of inertia are defined
                        as:
 - This card is represented as a property in HyperMesh.
