PARAM, W3
Bulk Data Entry Converts structural damping to equivalent viscous damping for transient analysis.
| Parameter | Values | Description |
| W3 | <Real> Default = 0.0 Used in transient analyses to convert structural damping to equivalent viscous damping.  |
                            The damping
                                matrix
                                     for transient analysis is assembled from:
 Where,
- This parameter can be specified in the Bulk Data section and/or Subcase section. If it is defined in the Subcase section, then it is subcase-specific and this value is only used for this subcase. This is done by defining PARAM, W3, <Real> for each subcase in the Subcase Information section.
 - PARAM, W3 is supported with direct transient, modal transient and nonlinear transient analysis types.
 - The order of priority is TSTEP or RSPINR/RSPINT entry, Subcase specific PARAM, followed by Bulk Data PARAM.
