PARAM, SIMPACK
Bulk Data Entry Requests generation of the SIMPACK .fbi file containing flexible body information for SIMPACK analysis.
| Parameter | Values | Description |
| SIMPACK | <1, 2, 3, 4, 5> | Requests generation of the
                                    SIMPACK
- Refer to the SIMPACK section of Create Output for Third Party Software in the User Guide for more information.
 - If PARAM, SIMPACK, 2 is specified in conjunction with the MODEL I/O Options Entry, only the model data specified in the MODEL entry is written to the SIMPACK .fbi file.
 - Units can be specified during the creation of the SIMPACK flex body .fbi file using DTI,UNITS.
 - A specific SET of grid points can be requested for output via the DISPLACEMENT I/O Options Entry for PARAM, SIMPACK, 3/4.
 - The flexible body information file (.fbi) is not generated unless a value of 1, 2, 3, 4, or 5 is specified for PARAM, SIMPACK.
