The radiation heat
                                    flux is:Where,
                                                - Stefan-Boltzmann constant
                                                  (PARAM,SIGMA).
                                                - Radiation heat flux.
                                                - Radiation view factor between the element face
                                                  and the ambient space node. This is defined on the
                                                  RADBC entry.
                                                - Surface emissivity of the surface element,
                                                  defined by EMIS1 on the RADM entry.
                                                - Surface absorptivity of the surface element,
                                                  defined by ABSORP field on the
                                                  RADM entry.
                                                - Surface temperature.
                                                - Absolute temperature scale defined via PARAM, TABS.
                                                - Ambient temperature.
                                         The temperatures and SIGMA
                                        should be defined in consistent units. Based on the input
                                        temperature units, the absolute temperature scale,
                                            , can be defined via
                                            PARAM,TABS. The value of
                                            SIGMA in SI units is 5.67E-8
                                            Watts/m2K4.  |
