Bulk Data Entry The old and new location of moved shell grid
        points are printed if SEP1XOVR = 16.
                            | Parameter |
                            Values |
                            Description |
                            | SEP1XOVR |
                            <0,
                                    16> |
                                        - 0 (Default)
                                        - The parameter is not present in the deck.
                                        - 16
                                                  - RSSCON
                                                  - The old and new location of moved shell grid
                                                  = 16, when the RSSCON
                                                  shell-to-solid element connector is used. By
                                                  default, the moved shell grid points are not
                                                  printed, SEP1XOVR =
                                                  0.
                                                  - RBE2GS
                                                  - The internally generated RBE2 elements are
                                                  printed when SEP1XOVR=16 when
                                                  RBE2GS entries are present in the model. These
                                                  internally generated RBE2 elements are printed in
                                                  a separate
                                                  <filename>.rbe2gs.fem
                                                  file.
                - This parameter cannot be specified in the input deck without a value.
                        OptiStruct will error out in this case.
