PARAM, INRELOUT
Bulk Data Entry Controls the output of inertia relief-corrected applied loading in conjunction with OLOAD request.
| Parameter | Values | Description |
| INRELOUT | <YES, NO> Default = NO  |
 Note: the OLOAD outputs for the following two
                                        cases always include inertia relief correction regardless of
                                            PARAM,INRELOUT:
