Bulk Data Entry Used to select the frequency response analysis
        formulation type for rotor dynamics analysis.
                            | Parameter |
                            Values |
                            Description |
                            | GYROAVG |
                            <0,
                                -1> |
                                        - 0 (Default)
                                        - The frequency-dependent rotor dynamics terms are
                                            calculated for each frequency. A frequency-dependent
                                            looping option is activated, however, the run time is
                                            higher compared to PARAM,
                                                GYROAVG, -1 as
                                            the calculation process has to be repeated for each
                                            frequency in the specified range.
                                        - -1
                                        - The frequency-dependent looping does not occur and an
                                            average frequency method is used to calculate the rotor
                                            dynamic terms. The run time is lower compared to
                                                PARAM,
                                            GYROAVG, 0 as this
                                            option avoids intensive calculations for each frequency.
                                                PARAM, WR3 and PARAM,
                                                WR4 must be specified for this formulation to
                                            include rotor damping. Alternatively,
                                                WR3 and WR4
                                            may be specified for each rotor in its corresponding
                                                RSPINR card.
                                Refer to Rotor Dynamics in the User
                                        Guide for more details.
