PARAM, GRDPNT
Bulk Data Entry Obsolete Nastran parameter that will give information about the mass properties of the structure.
| Parameter | Values | Description |
| GRDPNT | <GID> Integer ≥ -1  |
                            Activates output of Grid
                                Point Weight properties like center of gravity and moment of
                                inertia. This parameter does not affect output of
                                    OUTPUT,MASSPROP. It also
                                does not affect how mass properties are calculated within either
                                analysis or optimization solutions. This parameter is primarily to
                                generate output related to grid point weight properties to the
                                    .out file and does not affect the results
                                of the solution. Accepts either single integer input
                                        (GID) or multiple real values
                                        (X,Y,Z).
| <X,Y,Z> Real No default  |
                            The center of gravity coordinates are relative to <X,Y,Z> and expressed in the coordinate system CID. |
- The coordinate system CID is defined by PARAM, UCORD.
 - If PARAM, UCORD is not specified, CID = -1, or CID given is not found, all values are calculated relative to the basic coordinate system.
 - If PARAM, GRDPNT is not specified
                    in the input deck, then the corresponding printing of center of gravity and
                    moment of inertia are not output in the .out file
                    regardless of the value of PARAM,
                        UCORD.
If OUTPUT,MASSPROP is defined, the output of center of gravity and moment of inertia is available, regardless of PARAM,GRDPNT.
 - The values of PARAM, GRDPNT does
                    not affect the output of Center of Gravity and Mass Moment of Inertia output in
                        OUTPUT,
                            MASSPROP.
OUTPUT,MASSPROP related printing is in a different section of the .out file (compared to GRDPNT). Additionally, OUTPUT,MASSPROP printing is repeated for each optimization iteration (only once for analysis run). Whereas, PARAM,GRDPNT related output is only printed once at the beginning of the .out file.
 - If GID > 0, but the grid point is not found in the model, the center of gravity coordinates are relative to the origin of CID defined by PARAM, UCORD.
 - If the mass property is coupled due to inconsistent scalar mass, a Warning (No. 5606) with the corresponding coupling ratio will be printed to the .out file. In such situations, the output is provided in the principal directions.
 - Output with this PARAM is calculated based on mass matrix and in mesh dependent. On the other hand, the inertia calculated in optimization or OUTPUT,MASSPROP is done with proper integration for each element.
 - CMASS1 and CMASS2 elements can be excluded from Grid Point Weight Generation using PARAM,GRDPNTCM,NO.
