PARAM, EXPERTNL
Bulk Data Entry Activates a nonlinear expert system to aid in the convergence of Nonlinear (static and transient) Analysis.
| Parameter | Values | Description |
| EXPERTNL | <YES,
                                    NO, AUTO, or
                                    CNTSTB> Default = AUTO (For Small Displacement Analysis) For both Small and Large Displacement Analysis, Contact Stabilization is inactive by default.  |
                            PARAM,EXPERTNL has two functions embedded
                                within it:
 For Automatic Time-stepping Schema:
 For Contact Stabilization:
- The interaction of
                        PARAM, EXPERTNL, AUTO/YES with other nonlinear controls
                    during a nonlinear (static and transient) analysis is summarized as:
Option Controlled By Affected by EXPERTNL AUTO/YES DT, NINC NLPARM NO, these only control the initial increment size. MAXITER YES, MAXITER will be overridden by PARAM, EXPERTNL, AUTO/YES. MAXLS, LSTOL, TTERM NO PARAM, EXPERTNL, AUTO/YES does not affect any of the options in NLADAPT and TSTEP (in case of nonlinear transient analysis).
