PARAM, EFFMAS
Bulk Data Entry Outputs modal participation factors and effective mass for normal modes analyses.
| Parameter | Values | Description |
| EFFMAS | <YES,
                                    NO, Integer> Default = NO  |
 Where,
- PARAM,EFFMAS,YES outputs the specified matrices above for Normal Modes Analysis.
 - The MEFFMASS I/O Entry provides additional control over the normal modes analysis mass output, and can be used in place of PARAM,EFFMAS,YES, if the output is to be fine-tuned or if these matrices are to be output only for particular grids.
 - If OUTPUT,PUNCH is also specified along with PARAM,EFFMAS,YES, then the Modal Participation Factors, Modal Participation Factor Ratios, and the Modal Effective Mass matrices are printed to the Punch file, as well.
