- YES (Default)
                                        - The geometric quality of each element is checked. Any
                                            violation of the error limits is counted as a fatal
                                            error and the run will stop. Any violation of warning
                                            limits is non-fatal. Error or warning messages are
                                            printed for elements violating the limits along with the
                                            offending property values. The amount of output is
                                            limited to the first three occurrences for each
                                            individual case, plus a summary table of all
                                            errors.
                                        - NO
                                        - Element quality checks are not performed, but
                                            mathematical validity checks are performed.
                                        - FULL
                                        - The same checks are performed as for
                                                YES, but the error or warning
                                            messages are printed for all of the elements violating
                                            the error or warning limits.
                                See Element Quality Check for an overview of the element quality checking performed by
                                    the solver.
                                The ELEMQUAL Bulk Data
                                    Entry may be used to control the values for warning and error
                                    limits for each quality check, but validity limits cannot be
                                    altered manually.
