PARAM, AMLS
Bulk Data Entry Use external AMLS eigenvalue solver.
| Parameter | Values | Description |
| AMLS | <YES, NO> | This parameter is used to
                                invoke the external AMLS eigenvalue solver. This
                                solver is faster than the Lanczos solver for large eigenvalue
                                problems.
 Refer to AMLS (Automatic Multi-level Sub-structuring) Eigensolver in the User Guide for more details.  |
- AMLS must be installed on the system and the environment variable AMLS_EXE must point to the AMLS executable for this setting to work.
