PACPML
Bulk Data Entry Defines the properties of acoustic Adaptive Perfectly Matched Layer (APML) elements.
| PACPML | PID | MID | MODINT | ||||||
| ESBYL | TBYL | MESHG | MESHM | DBNAME | |||||
| EPS | XP | YP | ZP | ||||||
| MFID | NBND | BNDTYP | ADAPF | ||||||
| XRFL | YRFL | ZRFL | XFAC | YFAC | ZFAC |
| PACPML | 7 | 1 | 4 |
| PID | Unique property identification
                                        number. No default (Integer > 0)  |
| MID | Material identification number of a
                                        MAT10 material entry. No default (Integer > 0)  |
| MODINT | Modified integration element
                                    formulation option. 2
| ESBYL | Number of adaptively meshed
                                    elements to be present in the minimum wavelength of each
                                    frequency band. Default = 4.0 (Real)  |
| TBYL | Ratio of the thickness of each PML
                                    layer to the maximum wavelength of the frequency band.
                                         Default = 1.0 (Real)  |
| MESHG | Maximum Ratio between element size
                                    of a neighboring element and the size of a particular element.
                                         This option allows you to control neighboring element sizes to prevent poor meshes for PML computations. Default = 2.0 (Real)  |
| MESHM | Meshing method to be chosen for
                                    adaptive meshing.
| DBNAME | Database file name which is used to
                                    save meshes generated during the APML process.  Default = pml_DB (Character)  |
| EPS | Regularization parameter for
                                    distance field computation.  Default = 0.001 (Real)  |
| XP, YP, ZP | Coordinates of the pole of the APML
                                    acoustic elements (defined in the basic coordinate system).
                                         Default = Center of Gravity of PML layer (Real)  |
| MFID | Identification number of a
                                        MESHF Bulk Data Entry, which manually
                                    identifies the frequency bands for adaptive mesh generation.
                                         Default = Blank (Integer)  |
| NBND | Number of frequency bands in the
                                    range of frequencies (from the minimum to maximum frequency in
                                    the range). Default = Blank (Integer)  |
| BNDTYP | Scaling type to be used for
                                    frequency bands. 5
| ADAPF | Adaptive factor for generation of
                                    frequency bands (ratio between the maximum and minimum frequency
                                    for each band).  Default = 1.2 (Real)  |
| XRFL | Position of the reflection plane
                                    along the X-axis. The reflection plane is placed at this
                                    location along the X-axis and the plane is perpendicular to the
                                    X-axis. 11 Default = Blank (Real)  |
| YRFL | Position of the reflection plane
                                    along the Y-axis. The reflection plane is placed at this
                                    location along the Y-axis and the plane is perpendicular to the
                                    Y-axis. 11 Default = Blank (Real)  |
| ZRFL | Position of the reflection plane
                                    along the Z-axis. The reflection plane is placed at this
                                    location along the Z-axis and the plane is perpendicular to the
                                    Z-axis. 11 Default = Blank (Real)  |
| XFAC | Reflection factor for the
                                    reflection plane perpendicular to the X-axis. 11 Default = 1.0 (Real)  |
| YFAC | Reflection factor for the
                                    reflection plane perpendicular to the Y-axis. 11 Default = 1.0 (Real)  |
| ZFAC | Reflection factor for the
                                    reflection plane perpendicular to the Z-axis. 11 Default = 1.0 (Real)  |
- Adaptive Perfectly Matched Layer
                        (APML) mesh at the outer boundary of the acoustic domain ensures the
                        following conditions are satisfied:
- Acoustic waves at the interface do not get reflected.
 - Waves which pass through this layer are attenuated.
 - Direct and Modal Frequency Response Analysis are currently supported.
 - The four continuation lines in
                        this PACPML entry allow the definition of the following
                        characteristics:
- Line 1 – Definition and element formulation.
 - Line 2 – Adaptive APML mesh generation properties.
 - Line 3 – Distance field computation (determines the complex coordinate stretch direction).
 - Line 4 – Defines the frequency bands.
 - The modified integration flag in MODINT may be turned on to reduce the dispersion error (which is the error in the computed wavelength, measured relative to the actual wavelength, for an acoustics solution).
 - Adaptive meshing is automatically carried out either via HyperMesh or SimLab to generate the domain of the perfectly matched layer. It may be inefficient to generate a single PML mesh for the entire frequency range, as this mesh would be constrained to handle the full range of loading frequencies (from the lowest to the highest). A single mesh which handles the complete range of frequencies may lead to a very thick PML mesh layer and at the same time, a very fine mesh. Therefore, it is a good practice to divide the frequency range for mesh generation into multiple frequency bands. Likewise, it is not an efficient practice to generate one PML mesh for every single frequency of analysis.
 - A single adaptive mesh is generated per frequency band.
 - The regularization parameter is employed along with the pole in conjunction with the gradient of the distance field to determine the direction of the complex coordinate stretch.
 - The order of priority for frequency band generation is MFID > (NBND+BNDTYP) > ADAPF. If none of them are input, then the default of ADAPF = 1.2 is applied.
 - The NBND and
                            BNDTYP fields provide a way to determine the
                        frequency bands based on the following: Where:
- Number of bands (NBND)
 - where
 - Frequency bands
 - and
 - Minimum and maximum loading frequencies
Then based on the band distribution type (BNDTYP), the frequency bands are generated as:- Linear (BNDTYP=LIN) provides
                                    equal spacing for frequency bands.
 - Logarithmic (BNDTYP=LOG)
                                    provides larger spacing at higher frequencies.
 - Anti-logarithmic
                                        (BNDTYP=ALOG) provides
                                    larger spacing at lower frequencies.
 - ADAPF provides
                        an adaptive factor which defines each frequency band as:Where, .
 - When XRFL, YRFL, and/or ZRFL are specified, then there is a reflection plane perpendicular to the corresponding axes. The contribution of reflection planes to the far field pressure can be calculated based on the mirror rule. The reflection factor can be defined using the XFAC, YFAC, ZFAC fields. The reflection planes perpendicular to X, Y, and Z planes can exist simultaneously. There can only be one reflection plane defined for a particular axis.
