OMODES
I/O Options and Subcase Information Entry Used in the I/O Options or Subcase Information sections to request a set of modes for output requests for all subcases or for individual subcases, respectively. This command is applicable for normal modes and linear buckling solution sequences only.
OMODES = option
| Argument | Options | Description |
| option | <ALL, SID> Default = ALL  |
- When OMODES is not present, output is for all modes.
 - The SET definition referenced by the OMODES card must be an integer value set.
 - This output control is not available for frequency response subcases; OFREQUENCY should be used instead.
 - If both the OMODES and OFREQUENCY requests appear, the OMODES request takes precedence.
