NSGEADD
Bulk Data Entry Defines non-structural material damping as the sum of the sets listed.
NSGEADD | SID | S1 | S2 | S3 | S4 | S5 | S6 | S7 | |
S8 | S9 | S10 | etc. |
NSGEADD | 5 | 10 | 20 |
- Non-structural material damping in this format must be selected by the NSGE Subcase Information selector.
- No S# may be the identification number of a non-structural material damping set defined by another NSGEADD entry.
- NSGEADD entries take precedence over NSGE and NSGE1 entries. If both/all have the same SID, only the NSGEADD entry will be used.
- Optimization is currently not supported with non-structural damping.
