NOLIN2
Bulk Data Entry Defines nonlinear transient forcing functions of the form.
Pi(t)=S⋅Xj(t)⋅Xk(t)
Where, Xj(t) and Xk(t) can be either displacement or velocity at points GJ and GK, respectively, in the directions of CJ and CK, respectively.
NOLIN2 | SID | GI | CI | S | GJ | CJ | GK | CK |
NOLIN2 | 14 | 2 | 1 | 2.9 | 2 | 1 | 2 |
SID | Nonlinear load set
GI | Grid or scalar point
identification number at which nonlinear load is to be
applied. No default (Integer > 0) |
CI | Component number for
GI. No default (1 ≤ Integer ≤ 6; blank or 0, if GI is a scalar point) |
S | Scale factor. No default(Real) |
GJ, GK | Grid or scalar point
CJ, CK | Component number for GJ, GK according to the following table: |
Type | Displacement | Velocity |
Grid | 1 ≤ Integer ≤ 6 | 11 ≤ Integer ≤ 16 |
Scalar | Blank or 0 | Integer = 10 |
- Nonlinear loads must be selected by the Subcase Information data selector NONLINEAR.
- Nonlinear loads may not be referenced on a DLOAD entry.
- All degrees-of-freedom referenced on NOLIN2 entries must be members of the solution set.
- GI-CI, GJ-CJ and GK-CK may be the same degree-of-freedom.
- Nonlinear loads may be a function of
displacement
(X=˙u)
or velocity
(X=˙u)
. Velocities are denoted by a component number
ten greater than the actual component number; that is the component 11 indicates
velocity in the 1 component direction. The velocity is determined by:
- Time step interval.
- Displacement of GJ-CJ or GK-CK for the previous time step.
- The time step algorithm in transient solution sequences may loose unconditional stability when this load entry is used. In most practical cases, the time step size chosen to reach a certain accuracy is below the stability limit. It is recommended to decrease the time step if results diverge.
