The .mpcf file is an OptiStruct
        ASCII format results file.
File Creation
Creation of this file is controlled by the MPCFORCES I/O Option.
File Contents
                            | Result |
                            Description |
                            | Multi-point force of
                                constraint |
                                constraints for linear static analysis. |
File Format
The file is divided up by iteration. Output from each iteration starts with a line in the
                following format:
                                ITERATION |
                                Iteration_number |
                        - Data
                        - Description
                        - ITERATION
                        - Keyword denoting the beginning of a new iteration.
                        - Iteration_number
                        - Iteration number.
            Each iteration section contains the multi-point force of constraint for each node,
                for which this output format was selected, in each linear static subcase. Each
                subcase section is given the following header:
                                MPC forces for
                                    Subcase |
                                Subcase_id |
                        - Data
                        - Description
                        - Subcase_id
                        - User-defined subcase ID to which the mpc forces apply.
            MPC force information is then provided, for each node, in the
                following format:
                                Node_id |
                                x-force |
                                y-force |
                                z-force |
                                x-moment |
                                y-moment |
                                z-moment |
                        - Data
                        - Description
                        - Node_id
                        - Node identification number.
                        - x-force
                        - The x-translational component of the force at the node.
                        - y-force
                        - The y-translational component of the force at the node.
                        - z-force
                        - The z-translational component of the force at the node.
                        - x-moment
                        - The x-rotational component of the force at the node.
                        - y-moment
                        - The y-rotational component of the force at the node.
                        - z-moment
                        - The z-rotational component of the force at the node.
                - The I/O Option Previously Supported Results controls
                    the frequency of output for analytical results during an optimization.
