MONITOR
I/O Options and Subcase Information Entry Controls the printing of monitor point data to the .monpnt file, whenever monitor points (MONPT1/MONPNT2/MONPNT3) are defined in the model.
MONITOR (nopnt1, nopnt2, nopnt3) = option
MONITOR (NOPNT1) = ALL
MONITOR (NOPNT1, NOPNT2) = NONEDefinitions
| Argument | Options | Description |
| nopnt1 2 | <NOPNT1, blank> |
| nopnt2 2 | <NOPNT2, blank> |
| nopnt3 2 | <NOPNT3, blank> |
| option | <YES, ALL, NO,
                    NONE, blank> Default = ALL  |
- The MONITOR entry can be used for controlling the output only in case of linear static analysis. It has no effect in case of static aeroelastic analysis.
 - If a model has at least one load
                    monitor point
                        (MONPNT1/MONPNT2/MONPNT3)
                        defined:
- For linear static analysis, the .monpnt file will be generated only in the presence of the MONITOR I/O Option.
 - For static aeroelastic analysis, the .monpnt file will be generated automatically.
 - The output is printed to the .monpnt ASCII file.
