MODTRAK
Bulk Data Entry Defines parameters for mode tracking in optimizations with eigenvalue analysis.
| MODTRAK | SID | LOWRNG | HIGHRNG | MFILTER | TRAKSET | TRAKMETH |
| MODTRAK | 11 | 3 | 5 | 0.6 | 111 | 2 |
| SID | Set identification
                                    number. No default (Integer > 0)  |
| LOWRNG | Lowest mode number in
                                range to search.  Default = 0 (Integer ≥ 0)  |
| HIGHRNG | Highest mode number in
                                range to search.  Default = number of total modes (Integer ≥ 0)  |
| MFILTER | Filtering threshold used
                                in mode tracking.  Default = 0.7 (for CORC and MACSR), 0.5 (for MAC) (Real ≥ 0.0)  |
| TRAKSET | Element SET ID to define a
                                specific part of a model for mode tracking. Enables component-level
                                mode tracking. Default = blank (Integer > 0)  |
| TRAKMETH | Criterion employed for
                                mode tracking. 1 Default = 0 when TRAKSET=blank, 1 when TRAKSET is activated (0 = CORC, 1 = MACSR, 2 = MAC)  |
- The criteria available for
                        tracking are:
- Mass cross-orthogonality check (CORC)
 - Modal assurance criterion (MAC)
 - Modal assurance criterion square root (MACSR)
 - CORC criterion is not applicable when TRAKSET is activated.
 - This MODTRAK Bulk Data Entry should be referenced in a subcase via the MODTRAK Subcase Information Entry. PARAM, TRAKMETH and PARAM, MFILTER are ignored in the subcases that contain a MODTRAK Subcase Information Entry.
