MODCHG
Subcase Information Entry The MODCHG command can be used to remove and/or reactivate contact interfaces and/or elements for this subcase. It is used only for nonlinear analysis.
Contact activation or deactivation via
                    TYPE=CONTACT on the
                    MODCHG Bulk Data Entry is additionally supported for
                optimization runs.
Note: TYPE=ELMSET is not
                    supported for optimization.
MODCHG = option
| Argument | Options | Description |
| option | <SID> No default  |
- MODCHG Bulk Data Entries will not be used unless selected in the Subcase Information section.
 - For a fresh nonlinear analysis subcase (without any
                        CNTNLSUB or with CNTNLSUB prescribed
                    to be NO), a contact interface and a set of elements can be
                    active or inactive depending on whether and how they are referenced by
                        MODCHG.
- Contact and/or Elements
 - Active/Inactive
 - Removed with MODCHG
 - Inactive
 - Added with MODCHG
 - Active
 - Others
 - Active
 - For a subsequent nonlinear analysis subcase (with
                        CNTNLSUB prescribed to be YES or a
                    subcase ID), a contact interface and a set of elements can be active or inactive
                    depending on whether and how they are referenced by MODCHG
                    and whether they are active or not in the preceding subcase.
 - Active/Inactive
 - Inactive
 - Added with MODCHG
 - Active
 - Others
 - Active, if active in the preceding subcase
