Member Size Control
Allows you some control over the member size in the final topology and the resulting degree of simplicity of the final design.
This feature may be added one of the two ways.
Table 1. DOPTPRM Card
DOPTPR MINDIM VALUE
Here, only the preferred minimum diameter (width in 2D) of members may be defined as the VALUE field, following the MINDIM keyword. A global minimum member size is defined in this way.
Table 2. DTPL Card
DTPL ID PTYPE PID1 PID2 PID3 PID4 PID5 PID6
PID7 etc etc etc
MEMBSIZ MINDIM MAXDIM MINGAP
Here, both the preferred minimum, MINDIM, and the maximum, MAXDIM, diameter of members may be defined on the MEMBSIZ continuation line. Member size dimensions can be defined differently for each DTPL in this way. MINGAP defines the minimum spacing between structural members formed. It is only used in conjunction with MAXDIM. Usage of MAXDIM implies that the a MINGAP constraint of the same value as MAXDIM is applied. Therefore, for MINGAP to be effective, it should be greater than MAXDIM.
