MBFORCE
I/O Options and Subcase Information Entry The MBFORCE command can be used in the I/O Options section to request force output for a set of joints and/or force elements from multibody dynamics subcases.
MBFORCE = option
| Argument | Options | Description |
| option | <YES, ALL,
                        NO, NONE,
                    SID> Default = ALL  |
 Note: Joints and force elements may share IDs. When
                                        MBFORCE is requested for a
                                        SET, force results are output for all
                                    entities whose ID is part of the SET
                                    definition.
- When MBFORCE is not present, force results for joints and force elements are not output.
 - The force results for selected joints and force elements are output to the .mrf file.
