MBDSRF
Bulk Data Entry Defines a multibody deformable surface.
| MBDSRF | SRFID | NROW | NCOL | ENDTYPE | NSEGU | NSEGV | |||
| G1 | G2 | G3 | G4 | G5 | G6 | etc |
| MBDSRF | 1 | 3 | 6 | NATURAL | 100 | 100 | |||
| 201 | 202 | 203 | 204 | 205 | 206 | 207 | 206 | ||
| 209 | 210 | 211 | 212 | 213 | 214 | 215 | 216 | ||
| 217 | 218 |
| SRFID | Surface identification number. No default (Integer > 0)  |
| NROW | Number of rows of nodes. | |
| NCOL | Number of columns of nodes. | |
| ENDTYPE | Select from:
| NSEGU, NSEGV | Number of segments along the U and V coordinates
                                                  used to discretize the deformable surface for
                                                  animation purposes. No default (Integer > 0)  |
| G1, G2, … | Row-wise list of nodes. The first NROW IDs form the first row; the second NROW IDs form the second row, and so on. The list must contain a total of NROW*NCOL grid IDs. |
- The
                                                  deformable surface is generated using the CUBIC
                                                  spline interpolation which requires assumptions on
                                                  the second derivative of the interpolating
                                                  function at the end of the surface. The keywords
                                                  NATURAL,
                                                  PARABOLIC and
                                                  PERIODIC represent assumptions
                                                  defined as follows:
 - The MBDSRF element is not supported by the Force Imbalance method of static equilibrium.
 - The MBDSRF element does not possess any inherent inertia, stiffness or damping.
 - This card is represented as a set in HyperMesh.
