MATPZO
Bulk Data Entry Defines the coupling terms between structural and dielectric materials for defining a piezoelectric coupling.
| MATPZO | MID | PIEZO11 | PIEZO12 | PIEZO13 | PIEZO14 | PIEZO15 | PIEZO16 | FLAG | |
| PIEZO21 | PIEZO22 | PIEZO23 | PIEZO24 | PIEZO25 | PIEZO26 | ||||
| PIEZO31 | PIEZO32 | PIEZO33 | PIEZO34 | PIEZO35 | PIEZO36 | ||||
| DAMP | DPZO11 | DPZO12 | DPZO13 | DPZO15 | DPZO15 | DPZO16 | |||
| DPZO21 | DPZO22 | DPZO23 | DPZO25 | DPZO25 | DPZO26 | ||||
| DPZO31 | DPZO32 | DPZO33 | DPZO35 | DPZO35 | DPZO36 |
| MATPZO | 1 | 0.1 | 1.5 | 0.01 | STRS | ||||
| 0.01 | |||||||||
| 0.02 |
| MID | Unique material
                                identification number. No default (Integer > 0)  |
| PIEZOij | Coupling terms for the
                                piezoelectric material where i and
                                    j denote coordinate axes. 1Default = 0.0 (Real)  |
| FLAG | Flag to indicate the form
                                of the coupling terms (PIEZOij).
| DAMP | Flag to indicate the damping coefficients for piezoelectric coupling terms. | |
| DPZOij | Coupling terms for the
                                piezoelectric damping where i and
                                    j denote coordinate axes.Default = 0.0 (Real)  |
- Values in PIEZOij and DPZOij can be blank, but at least one non-zero value of PIEZOij and DPZOij must be defined for a MATPZO Bulk Data Entry.
 - The material identification number can be the shared with structural materials (MAT1, MAT2, MAT8, MAT9 or MGASK), thermal materials (MAT4, MAT5), or electrical materials (MAT1EC, MAT2EC) but must be unique with respect to other dielectric materials (MAT1PT, MAT2PT).
 - MATPZO is supported for solid elements only.
 - The formulation is as follows:
- When FLAG=STRSCHG, the
                                piezoelectric material matrix has the following
                                    form:
 - When FLAG=STRNCHG, the
                                coefficients form the coupling matrix
                                     as:The matrix is converted to the matrix by:
- Elastic material matrix
 - Permittivity matrix defined by MAT1PT or MAT2PT
 - Refers to the coupling terms ( ) when FLAG=STRSCHG
 - Refers to the coupling terms ( ) when FLAG=STRNCHG
                                    form:
 - For more information, refer to Piezoelectric Analysis in the User Guide.
