MATHC
Bulk Data Entry This material data defines honeycomb material behavior in Explicit analysis.
The material is used to describe honeycomb and foam with anisotropic behavior. The nonlinear elastoplastic material can be defined separately for all normal and shear behavior for uncompacted configuration, and isotropic material model is considered for a fully compacted model. This material is available for solid elements.
MATHC | MID | E | NU | RHO | SIGY | VF | |||
LCA | LCB | LCC | LCAB | LCBC | LCCA | ||||
EAAU | EBBU | ECCU | GABU | GBCU | GCAU |
MID | Material
E | Young's Modulus for the compacted honeycomb material No Default (Real > 0) |
Nu | Poisson’s ratio for the compacted honeycomb material. No Default (Real > 0) |
RHO | Mass Density. No Default (Real > 0) |
SIGY | Yield stress for the fully compacted honeycomb material.
VF | The relative volume at which the honeycomb material is fully
compacted. No Default (0 < Real < 1) |
LCA | Identification number of function for sigaa versus volumetric
strain. No Default (Integer > 0) |
LCB | Identification number of function for sigbb versus volumetric
LCC | Identification number of function for sigcc versus volumetric
LCAB | Identification number of function for sigab versus volumetric
LCBC | Identification number of function for sigbc versus volumetric
LCCA | Identification number of function for sigca versus volumetric
EAAU | Initial Young's Modulus Eaa in the uncompacted configuration.
EBBU | Initial Young Modulus Ebb in the uncompacted configuration.
ECCU | Initial Young's Modulus Ecc in the uncompacted configuration.
GABU | Initial shear modulus Gab in the uncompacted configuration.
GBCU | Initial shear modulus Gbc in the uncompacted
configuration. No Default (Real > 0) |
GCAU | Initial shear modulus Gca in uncompacted configuration. No Default (Real > 0) |
- Uncompacted Honeycomb Material V > VF
The Behavior before compaction is orthotropic and the stresses are completely uncoupled. The elastic moduli by direction vary from their initial value to the isotropic fully compacted value E at Vf as:
Eaa=Eaau+β(E−Eaau)Ebb=Ebbu+β(E−Ebbu)Ecc=Eccu+β(E−Eccu)Gab=Gabu+β(G−Gabu)Gbc=Gbcu+β(G−Gbcu)Gca=Gcau+β(G−Gcau)With β=max[Min(1−V1−VF,0),1] and G=E2(1+ν)V is relative volume and VF is the relative volume at which the honeycomb is compacted. For the uncompacted configuration the trial stress components are updated as:
σtrialaa(tn+1)=σtrialaa(tn)+EaaΔϵaaσtrialbb(tn+1)=σtrialbb(tn)+EbbΔϵbbσtrialcc(tn+1)=σtrialcc(tn)+EccΔϵccσtrialab(tn+1)=σtrialab(tn)+2GabΔϵabσtrialbc(tn+1)=σtrialbc(tn)+2GbcΔϵbcσtrialca(tn+1)=σtrialca(tn)+2GcaΔϵbcEach stress component must not exceed the permissible values given by the stress versus volumetric strain defined by the curve (LCAA, LCBB, … and so on) for each component.
|σtrialij(tn+1)|<σij(V)Thus,σij(tn+1)=σij(V)σtrialij(tn+1)|σtrialij(tn+1)|The σij(V) is defined for each component using LCAA, LCBB, LCCC … (see Figure 1). - Compacted Honeycomb Material V < VF
For the fully compacted honeycomb material, assume the behavior is isotropic and elastic perfectly plastic. Thus, the stress is updated using Hook Material law. So, the deviatoric stresses are given by:
Strialij(tn+1)=Sij(tn+1)+2GΔεdevijWhere the deviatoric strain increment is defined by:Δεdevij=εij−13ΔεkkδijThe equivalent Von Mises stress of the fully compacted honeycomb material is compared to the SIGY. If the effective stress exceeds the yield stress, the tensor stress is simply scaled back to the yield surface using:
Sij(tn+1)=σyStrialeq Striaij(tn+1)Where Strialeq=(32 Striaij Striaij)12The pressure is updated using the Bulk modulus as:
P(tn+1)=P(tn)−KΔεkkWhere K=E3(1−2ν)Thus, the final Cauchy stress is computed as:
σij(tn+1)=Sij(tn+1)−P(tn+1)δijFigure 1. Stress versus Volumetric Strain
