MATF3
Bulk Data Entry Specifies frequency-dependent material properties on MAT3 entry fields via TABLEDi entries.
| MATF3 | MID | T(EX) | T(ETH) | T(EZ) | T(NUXTH) | T(NUTHZ) | T(NUZX) | T(RHO) | |
| T(XTH) | T(THZ) | T(GZX) | T(AX) | T(ATH) | T(AZ) | T(GE) |
| MATF3 | 17 | 32 | 19 | ||||||
| 52 |
| MID | Material property identification number that
                                                  matches the identification number on the
                                                  MAT3 entry. (Integer > 0)  |
| T(EX), T(ETH), T(EZ) | TABLEDior TABLEMi entry identification
                numbers for Young's moduli in the x,
         and z directions. Default = blank (Integer ≥ 0 or blank)  |
                numbers for Poisson's ratios in the x
        z and zx directions. Default = blank (Integer ≥ 0 or blank)  |
| T(RHO) | A
                  TABLEDi or TABLEMi entry identification
                number for the mass density. Default = blank (Integer ≥ 0 or blank)  |
| T(XTH), T(GZX), T(THZ) | A
                number for the shear moduli in the x
| T(AX), T(ATH), T(AZ) | TABLEDi or TABLEMi entry identification
                numbers for thermal expansion coefficients in the x,
         and z directions. Default = blank (Integer or blank)  |
| T(GE) | A
                number for the damping coefficient. Default = blank (Integer > 0 or blank)  |
- Fields 3, 4, and so on of this entry correspond, field-by-field, to fields 3, 4, and so on of the MAT3 entry referenced in field 2. The value in a particular field of the MAT3 entry is replaced or modified by the table referenced in the corresponding field of this entry. In the example, EX is modified; TABLEDi 32, RHO is modified by TABLEDi 19; and GE is modified by TABLEDi 52.
 - Blank or zero entries mean that there is no frequency dependence of the field on the MAT3 entry. Any quantity modified by this entry must have a value on the MAT3 entry.
 - In Modal Frequency Response Analysis, the frequency-dependency is only used in the frequency response part of the solution, not in the modal analysis part of the solution.
 - OptiStruct accepts both MATF3 and MAT3F for this entry.
 - A matching TABLEDi ID is checked first, and if no such entry exists, then a TABLEMi ID match is checked. If a matching table ID does not exist for both entries, the run errors out.
 - This card is represented as a material in HyperMesh.
