MATBRT
Bulk Data Entry Defines the material properties for Brittle Damage material models.
MATBRT MID
CRACK OPTION
V1 V2
etc. etc.
SHEAR OPTION
V3 V4
etc. etc.
FAILURE NDIR
V5 PFAIL
MATBRT 2
CRACK ENER
250.0 0.4
MID Material identification number.
No default (Integer > 0)
CRACK Flag indicating that parameters for tensile cracking behavior are to follow. 3
OPTION The following options are available for tensile crack behavior (Mode I):
STRN
Crack opening is expressed in the form of positive principal stress versus crack opening strain.
DISP
Crack opening is expressed in the form of positive principal stress versus crack opening displacement.
ENER
Crack opening is expressed in the form of positive principal stress and fracture energy.
blank (Default)
3
V1, V2 Values of V1 and V2 depend on the OPTION chosen for tensile crack behavior. 3 [Pa][Pa] for V1
[m][m] for V2 if OPTION= DISP or ENER
SHEAR Flag indicating that the parameters for shear cracking behavior are to follow. 4
OPTION The following options are available for shear crack behavior (Mode II):
RFAC
Crack opening is expressed in the form of retention factor versus crack opening variable.
The variable is strain if CRACK OPTION=STRN is specified; it is displacement if CRACK OPTION=DISP or ENER.
PLAW
Crack opening is expressed in the form of power law factor and maximum crack opening variable.
blank (Default)
4
V3, V4 Values of V3 and V4 depend on the OPTION chosen for shear crack behavior. 4
[m][m] for V4 if OPTION= DISP or ENER
FAILURE Flag indicating parameters for defining the limit of element deletion with the crack opening.
NDIR Number of directions that should reach the critical crack opening value (V5) before element deletion.
1 (Default)
1 or 2
Shells
1, 2, or 3
Solids
V5 If the CRACK OPTION=STRN, defines the value of critical strain crack opening ( εckcritεckcrit ).
If the CRACK OPTION=DISP or ENER, defines the value of critical displacement crack opening ( uckcrituckcrit )
Default = blank (Real)
[m][m] for V5 if OPTION= DISP or ENER
PFAIL Percentage of failed integration points prior to element deletion.
Default = 1.0
  1. MATBRT is currently supported only for explicit dynamic analysis (NLEXPL).
  2. A MATBRT entry should have the same MID as a MAT1 entry in the same model. The MAT1 entry is used to define the linear isotropic elastic behavior prior to crack initiation. The curves defined in the comments below define only the cracking behavior post crack initiation.
  3. For tensile crack, there is no change to compression behavior and only tensile cracking is considered. CRACK defines the tensile crack behavior (Mode I):
    STRN
    Crack opening is expressed in the form of positive principal stress ( σItσIt ) versus crack opening strain ( εcknnεcknn ). The series of values (V1, V2) define a table of ( σItσIt , εcknnεcknn ).
    Figure 1. STRN Option for Tensile CRACK
    DISP
    Crack opening is expressed in the form of positive principal stress ( σItσIt ) versus crack opening displacement ( ucknnucknn ). The series of values (V1, V2) define a table of ( σItσIt , ucknnucknn ).
    Figure 2. DISP Option for Tensile CRACK
    ENER
    Crack opening is expressed in the form of positive principal stress ( σItuσItu ) and fracture energy ( GIfGIf ). The value of V1 is σItuσItu and V2 is GIfGIf .
    Figure 3. ENER Option for Tensile Crack
  4. For shear crack, the SHEAR flag defines the shear crack behavior (Mode II):
    RFAC
    Crack opening is expressed in the form of retention factor ( ρρ ) versus crack opening variable chosen for CRACK OPTION (STRN= εcknnεcknn , DISP or ENER= ucknnucknn ). The series of values (V3, V4) defines a table of ( ρρ , εcknnεcknn ) or ( ρρ , ucknnucknn ).
    Gdamagedshear=ρ*GshearGdamagedshear=ρ*Gshear
    Where ρρ is a function of εcknnεcknn or ucknnucknn ; the range of ρρ is from 1.0 to 0.0.
    Figure 4. RFAC Option for SHEAR Cracking with STRN Option in CRACK Definition
    Figure 5. RFAC Option for SHEAR Cracking with DISP/ENER Option in CRACK Definition
    The shear modulus is multiplied by the variable ρρ during the crack propagation.
    PLAW
    Retention factor ρρ is expressed in the form of a power law. This power law evolves following the crack opening variable chosen in the CRACK definition (STRN= εcknnεcknn , DISP or ENER= ucknnucknn ):
    Gdamagedshear=(1εcknnεckmax)pGshearGdamagedshear=(1εcknnεckmax)pGshear
    or,
    Gdamagedshear=(1ucknnuckmax)pGshearGdamagedshear=(1ucknnuckmax)pGshear
    Two parameters are expected. The value of V3 is εckmaxεckmax or uckmaxuckmax , the maximum crack opening variable, and V4 is ρρ , the power exponent.
    Figure 6. PLAW Option for SHEAR Cracking with STRN Option in CRACK Definition
    Figure 7. PLAW Option for SHEAR Cracking with DISP/ENER Option in CRACK Definition
  5. FAILURE defines the limit of element deletion with the crack opening. Each principal stress over all directions of the element is used to compute a specific crack opening variable. NDIR is the number of principal directions that have reached the critical crack opening variable value V5 triggering the element deletion; at least 1 direction is mandatory. For shells there can be a maximum of 2 directions, and for solids 3 directions.
