MASSSET
Bulk Data Entry Defines a linear combination of mass cases to form the subcase dependent mass.
MASSSET ID SA S0 ID0 S1 ID1 S2 ID2
S3 ID3 etc.
MASSSET 10 1.0 1.0 0 1.0 10
ID Identification number referenced by MASSSET Subcase Information Entry.
No default (Integer > 0)
SA The overall scale factor for the linear combination.
Default = 0.0 (Real)
Si The scale factor for the linear combination.
IDi The MASSID for the i'th mass section. This is the ID defined on the SEID field of the BEGIN,MASSID entry to identify the corresponding mass section.
  1. This entry is referenced by the MASSSET Subcase Information Entry.
  2. Fixed reference frame method is adopted for 3D rotor dynamic analysis.
  3. The mass of a section is calculated as:
    MID=S0iSiMi
    Where,
    MID
    Mass of the linear combination of mass cases.
    S0
    Overall scale factor of the linear combination.
    Si
    Scale factor of the i'th mass section.
    Mi
    Mass of the i'th mass section identified by the IDi field. It is the mass of the mass section defined on the corresponding BEGIN,MASSID entry.
    i
    ID of the MASSID section; i = 0 is the base mass case.
  4. IDs for mass sections defined on the MASSSET Bulk Data Entry should be unique.
