The .load file is an OptiStruct
        ASCII format results file.
File Creation
Creation of this file is controlled by the OLOAD I/O
                Option.
File Contents
                            | Result |
                            Description |
                            | Applied Load |
                            Applied load vectors in
                                the Global Coordinate System (see CID in Grid ) for linear static
                                analysis. |
File Format
            The applied load file has the following format:
                                | For each iteration, the following header is
                                    used: |
                                iter |
                                Iteration |
                                NumIds |
                        - Data
                        - Description
                        - iter
                        - Keyword denoting the beginning of a new iteration.
                        - Iteration
                        - Iteration number.
                        - NumIds
                        - Number of subcases for which this output is created.
            Each iteration section is divided up by subcase. Output for each subcase starts with
                a line in the following format:
                                Id |
                                Number_of_nodes |
                                Frequency |
                                LOAD:
                                        Spc_id(Datatype) |
                                subcase_label |
                        - Data
                        - Description
                        - Id
                        - Output identification number for the subcase. This is not the same as
                            the subcase ID used in the input data.
                        - Number_of_nodes
                        - Number of nodes for which this output is requested.
                        - Frequency
                        - Is 1.0 for static analysis.
                        - LOAD
                        - Keyword declaring applied load information.
                        - Spc_id
                        - SID for SPC's referenced by this subcase.
                        - Datatype
                        - Keyword indicating the type of subcase involved.
                        - LOAD declares data is for a linear static
                            subcase.
            The following information is then provided for each node, for which this output was
                    requested:
                                NID |
                                X force |
                                Y
                                        force |
                                Z force |
                                X
                                        mom |
                                Y mom |
                                Z
                                        mom |
                        - Data
                        - Description
                        - NID
                        - Node identification number.
                        - X force
                        - X force at the node.
                        - Y force
                        - Y force at the node.
                        - Z force
                        - Z force at the node.
                        - X mom
                        - X moment at the node.
                        - Y mom
                        - Y moment at the node.
                        - Z mom
                        - Z moment at the node.
                - The I/O Option Previously Supported Results controls
                    the frequency of output for analytical results during an optimization.
