INVELB
Bulk Data Entry Defines initial velocity in a multibody situation.
| INVELB | SID | BID | CID | ||||||
| VX | VY | VZ | WX | WY | WZ |
| INVELB | 1 | 3 | |||||||
| 1000.0 |
| SID | Load set identification
                  number. (Integer > 0)  |
| BID | Body identification number. (Integer > 0)  |
| CID | Reference coordinate system. A
                  CID of zero or blank references the basic coordinate
                  system. (Integer > 0)  |
| VX, VY, VZ | Translational velocities. (Blank or Real)  |
| WX, WY, WZ | Rotational velocities. (Blank or Real)  |
- Only one initial velocity per body can be defined in a load set.
 - This card is represented as a load collector in HyperMesh.
