INISTRS
Bulk Data Entry Defines initial stress values and settings for elements in nonlinear analysis.
| INISTRS | ID | ETYPE | CIDA |
| SECT | NSEC | SEC1 | SEC2 | SEC3 | etc. |
| EORS | EID/ESETID | CIDB | |||||||
| VALUE | STRS1 | STRS2 | STRS3 | etc. |
When ETYPE = SHELL and the SECT line is given, each VALUE line defines initial stress for a shell section; and so, for any shell element (with EID) or shell element set (with ESETID), the number of VALUE lines must be NSEC.
Alternate Format (Initial Stress from H3D file)
| INISTRS | ID | ASSIGN | SUBID | ||||||
| EORS | EID1/ ESETID1 | EID2/ ESETID2 | EID3/ ESETID3 | EID4/ ESETID4 | EID5/ ESETID5 | EID6/ ESETID6 | EID7/ ESETID7 | ||
| EID8/ ESETID | etc. | etc. |
Alternate Format (Initial Stress from external results LS-DYNA .k file)
| INISTRS | ID | ASSIGN | MAP | ||||||
| RELOC | RTYPE | PA1 | PA2 | PA3 | PB1 | PB2 | PB3 |
| UNITS | SI/CGS/MPA/BG | MASS | FORCE | LENGTH | TIME |
Example 1
| INISTRS | 7 | ||||||||
| ELEM | 1001 | ||||||||
| VALUE | 3.5e4 | -1.5e3 | 0.0 | 3.0e3 | 0.0 | 2.0e3 | |||
| ESET | 200 | ||||||||
| VALUE | 3.0e4 | -1.5e3 | 0.0 | 3.0e3 | 0.0 | 2.0e3 |
Example 2
| INISTRS | 8 | SHELL | -1 | ||||||
| SECT | 2 | ||||||||
| ELEM | 101 | ||||||||
| VALUE | 3.5e4 | 0.0 | 0.0 | ||||||
| VALUE | -3.5e4 | 0.0 | 0.0 | ||||||
| ELEM | 102 | ||||||||
| VALUE | 3.0e4 | 0.0 | 0.0 | ||||||
| VALUE | -3.0e4 | 0.0 | 0.0 |
Example 3 (Alternate Format – Stress from H3D file)
| INISTRS | 7 | 19 | 3 | ||||||
| ELEM | 1001 | 2002 | 3003 |
Example 4 (Alternate Format – Stress from H3D file)
| INISTRS | 8 | 29 | 6 | ||||||
| ESET | 2 | 5 | 9 | ||||||
| ESET | 9 | 19 | 29 |
Example 5 (Alternate Format – Stress from LS-DYNA .k file)
| INISTRS | 9 | 25 | |||||||
Example 6 (Specify Units of the External File)
| UNITS | SI | KG | N | M | S |
| ID | Unique identification
                                        number. No default (Integer > 0)  |
| ETYPE | Element type which
                                    initial stress is applied.
| CIDA | Coordinate system
                                    identification number, or stress components flag.
 Integer > 0: user-defined (prescribed) coordinate system.  |
| SECT | Keyword indicating the start of continuation line(s) for the shell sections. | |
| NSEC | Number of shell
                                    sections where initial stress is applied for shell elements.
                                         No default (1 ≤ Integer ≤ 6)  |
| SEC(i) | Through-thickness
                                    position for the shell sections. SEC(i) must
                                    be either all blank or all non-blank, that is, the number of
                                        SEC(i) must be either
                                        NSEC or zero; and
                                        SEC(i) must be given in ascending order
                                    if all non-blank. Blank implies that the sections are located uniformly through the shell thickness, starting at the bottom surface and ending at the top surface. A Real value is the multiplier to shell thickness to get the location. -0.5 means the bottom surface of the shell element and 0.5 means the top surface. The through-thickness positive direction, pointing from the bottom surface to the top surface, is determined by the right-hand rule and the order in which the grid points are listed on the connection entry. It is same as the convention for Z1/Z2 of PSHELL. <Blank, or -0.5 ≤ Real ≤ 0.5> Default = Blank  |
| EORS | Flag indicating an
                                    element, or element SET is selected in the
                                    following field.
| EID/ESETID | Identification number
                                    of the element or element SET to which the
                                    stress values apply. No default (Integer > 0)  |
| CIDB | Coordinate system
                                    identification number or stress components flag.
| VALUE | Keyword indicating the start of a continuation line for the stress components. | |
| STRS(i) | Stress components
                                        4 No default (Real)  |
| Alternate Format Definitions (Stress from H3D file): 5 | ||
| ASSIGN | Identification number
                                    of ASSIGN, H3DRES. When
                                        ASSIGN is specified,
                                        SUBID should be specified as well, and
                                        “VALUE” continuation line is not
                                        allowed. This field is mandatory for Alternate Format (Stress from H3D file). No default (Integer > 0)  |
| MAP | Mapping control
                                    options.
 Default = AUTO (AUTO, ID, or Blank)  |
| SUBID | Subcase identification
                                    number where initial stress is applied from a
                                        H3D file. This field is mandatory for Alternate Format (Stress from H3D file). No default (Integer > 0)  |
                                    following field.
| EID#/ESETID# | Identification number
                                    of the element or the element SET to which
                                    the stress values apply. No default (Integer > 0)  |
| Alternate Format Description (Stress from external results LS-DYNA .k file): 6 | ||
                                    of ASSIGN,MANUF.  This field is mandatory for Alternate Format (Stress from external results .k file) No default (Integer > 0)  |
                                    element, or an element SET is selected in the following field.
                                    of the element or the element SET to which the stress values
| Optional Continuation Line Options for Relocation: | ||
| RELOC | Activates the
                                    Relocation option. 7
                                     The matching grid point ID pairs in the model and external result file are to follow.  |
| RTYPE | Relocation type.
| PA1, PA2, PA3 | IDs of three non-collinear grid points in the model. | |
| PB1, PB2, PB3 | IDs of three non-collinear grid points in model from the external result file that are matched to corresponding grid points in the structure (PA1, PA2, PA3, respectively). | |
| UNITS |
 No default  |
| MASS | Units of mass.
| FORCE | Units of force.
| LENGTH | Units of length.
| TIME | Units of time.
- INISTRS and ISTSADD should not have the same ID.
 - The INISTRS Bulk Data Entry is selected by the Subcase Information command INISTRS.
 - Initial stress is supported for solid
                    elements (CHEXA, CPENTA,
                        CPYRA and CTETRA) and shell elements
                        (CQUAD4, CTRIA3,
                        CQUAD8 and CTRIA6), only.
Initial stress is currently not supported for solid elements with hyperelastic material in LGDISP analysis.
 - For initial stress of solid elements, 6 stress
                    components are needed for each VALUE line and they are:
- STRS1
 - xx
 - STRS2
 - yy
 - STRS3
 - zz
 - STRS4
 - xy
 - STRS5
 - yz
 - STRS6
 - zx
For initial stress in element or material coordinate system of shell elements, 3 stress components are needed for each VALUE line and they are:- STRS1
 - STRS2
 - STRS3
For initial stress in the basic or a prescribed coordinate system of shell elements, 6 stress components are needed for each VALUE line and they are:- STRS1
 - xx
 - STRS2
 - yy
 - STRS3
 - zz
 - STRS4
 - xy
 - STRS5
 - yz
 - STRS6
 - zx
 - Alternate Format (Stress from H3D file):
- VALUE continuation line is not allowed for the Alternate Format when Stress is sourced from a H3D file.
 - For Shell elements, currently only the equivalent of NSEC=2 is supported (Z1 and Z2 layers) to apply the initial stress, as the number of layers where stress data is available can be identified from the H3D file.
 - Currently only H3D files output from OptiStruct and HyperForm are supported.
                    .k file):
- VALUE continuation line is not allowed for the Alternate Format when Stress is sourced from .k file.
 - Currently only .k file output from LS-DYNA is supported.
 - Relocation continuation line:
- The RELOC entry and its related fields define three matching grid point pairs on the model and the external result file. The result from the external file is relocated (translated and rotated, as required) such that the three non-collinear grid points PB1, PB2 and PB3 coincide with PA1, PA2, and PA3, respectively.
